Dim3nsioneer 557
Well, a 3D printer could be made more intelligent, maybe just not for the same price.
I assume the x-ray view has some kind of drawing routine in which is decided to draw certain parts in red, right? This would have to be used as an output somehow to trigger a message as suggested by the OP.
ahoeben 1,968
Actually. all of this is surprisingly hard to detect.
I often explain how "stupid" a 3d printer is. It just does what it is being told, without knowing what the result should be. If something goes wrong, causing spaghetti, the printer just happily plods along because it does not know something is going wrong. Well, software is pretty much the same. It does what it is instructed to do, and does not know what the output should be. If the input is shit, the output is going to be shit, but knowing if the input is shit is hard.
Can checks be created, inspecting the quality of meshes? Sure, but it is not easy. Even something as evident as X-Ray, showing red areas where there is an issue, is hard to do somewhat reliably for a computer (we would quite literally have to check if any pixels end up being red by looking at each resulting pixel one at a time). The X-Ray view is purely a visualisation "trick" that is much easier to inspect for users than for computers.
