@Eldrick, please keep your personal frustrations in check. There is no reason to assume that @GuusR is affected by the same issue as you are. As far as I can see OP is using a single extrusion printer.
@GuusR, can you post logs somewhere so we can see what is going wrong?
https://github.com/Ultimaker/Cura/blob/master/README.md
Please don't paste the logs here, because they will likely be very large and the forum will mangle the input. Instead, please post them on eg pastebin.com and post a link here.
1
eldrick 65
Based on the assumption that their customers are too stupid to use the feature without hurting something, the developers intentionally disabled sequential printing in 2.7.
There is another recent thread that calls out a tweak to re-enable it for those capable of arranging objects on a buildplate.
Edited by GuestLink to post
