First why would you have to replace everything if you did a good cleaning? can't imaging you broke all parts?
I don't think you quite understand the situation. Melted filament got everywhere on the metal parts of the hot end. In every crack, gap and hole there is. After heating up the Olson block to pull what filament I could off it it, I had to use a torch to melt/burn the rest of the filament off. Even doing that didn't quite get all of the filament (there are still spots that I just could not get into with the torch, wire brush, or fine grit sand paper to clean it up).
I cleaned it up pretty good considering the situation it was in, and it functions, but its not pretty. I used a wire brush and fine grit sand paper to get what glue/char that I could, but even after that most of the parts are discolored because of the high heat from the torch. Most of this is hidden behind the fan shroud, sure, but I would like to replace the parts anyway. Not only for aesthetics, but because its difficult to remove the Olson block, the metal coupler, and the nozzle unless its at full temperature because all of the threads have just a little bit of filament or char on them that I just cannot clean off. This is even worse for the Heater and Thermistor since I cannot remove those unless its at full temperature, but once I remove them from the Olson block, they go crazy because the Thermistor is no longer reporting the actual temperature of the heater because they are separate.
Changing nozzles on a V6 is super annoying vs the ease of an olssonblock.
The only time I ever change a nozzle is when there is a problem, so I am not too worried about this.
The full metal 2,85 version is a pain to use with PLA (again imho)
Why is it a pain? Can you elaborate?
Probably the nicest upgrade would be to use a head with a single UM3 CORE.
I am only really interested in the UM3 Cores if someone manages to make a UM3 print head that can attach to the UM2+. Are there other compatible aftermarket hot ends that are as good as the UM2+ one?
ultiarjan 1,223
the E3DV6 vs UM2+Olssonblock choice is a simple decision, the V6 is a huge downgrade imho. Changing nozzles on a V6 is super annoying vs the ease of an olssonblock.
The E3DV6 can be very confusing, as there are multiple version around. The full metal 2,85 version is a pain to use with PLA (again imho). The only reason I would consider a V6 is for an experimental setup for high temp materials.
Probably the nicest upgrade would be to use a head with a single UM3 CORE. I made a first version a long time ago as a proof of concept. I expect more versions to pop up once the UM3 design files will be released next week.
Edited by GuestLink to post
