Posted · Cura 2.7 Crashing Consistently
Cura 2.7 is crashing anytime I try to open an stl file via file/open
The same happens when trying to load a profile as well.
If I drag and drop an stl file onto the build plate it's saying failed to load.
What the heck is going on??
    Probably because the STL file is corrupt. Did you create it with sketchup? its rather infamous for creating incorrect stls.
    If that's not the case, we will need log files to help you.
    Posted (edited) · Cura 2.7 Crashing Consistently
    It was not created by me. I don't believe it's a corrupt stl, as I am able to get it to open after multiple attempts of it failing/ crashing the app.  If I open another STL first , that one is sometimes successful other times fails as well.  I can't seem to find a pattern to it.
    Additionally, every time I go to File/ Open Files ... the Open files window appears but then  Cura will crash a few seconds later, even if I do not select any file.
    2017-10-12 08:08:05,033 - DEBUG - UM3NetworkPrinting.NetworkPrinterOutputDevicePlugin._onServiceChanged [210]: Bonjour service added: ultimakersystem-ccbdd3002d90._ultimaker._tcp.local.
    2017-10-12 08:08:09,329 - DEBUG - UM3NetworkPrinting.NetworkPrinterOutputDevice._onFinished [954]: We got a response (http://192.168.1.31/api/v1/printer) from the server after 58845.5 of silence. Going back to previous state ConnectionState.connected
    2017-10-12 08:09:09,770 - DEBUG - CuraEngineBackend.CuraEngineBackend._terminate [244]: Attempting to kill the engine process
    2017-10-12 08:09:09,770 - DEBUG - CuraEngineBackend.CuraEngineBackend._terminate [250]: Killing engine process
    2017-10-12 08:09:09,774 - DEBUG - CuraEngineBackend.CuraEngineBackend._terminate [253]: Engine process is killed. Received return code 1
    2017-10-12 08:09:09,789 - DEBUG - UM.Backend.Backend._createSocket [214]: Previous socket existed. Closing that first.
    2017-10-12 08:09:09,832 - DEBUG - UM.Backend.Backend._logSocketState [174]: Socket state changed to Listening
    2017-10-12 08:09:09,845 - INFO - UM.Backend.Backend.startEngine [75]: Started engine process: C:\Program Files\Cura 2.7\CuraEngine.exe
    2017-10-12 08:09:09,856 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Calling engine with: ['C:\\Program Files\\Cura 2.7\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '-j', 'C:\\Program Files\\Cura 2.7\\resources\\definitions\\fdmprinter.def.json', '']
    2017-10-12 08:09:09,896 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:09,907 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Cura_SteamEngine version DEV
    2017-10-12 08:09:09,919 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Copyright © 2014 David Braam
    2017-10-12 08:09:09,922 - DEBUG - UM.Backend.Backend._logSocketState [178]: Socket state changed to Connected
    2017-10-12 08:09:09,923 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:09,926 - DEBUG - UM.Backend.Backend._onSocketStateChanged [168]: Backend connected on port 49674
    2017-10-12 08:09:09,932 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] This program is free software: you can redistribute it and/or modify
    2017-10-12 08:09:09,946 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] it under the terms of the GNU Affero General Public License as published by
    2017-10-12 08:09:09,982 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] the Free Software Foundation, either version 3 of the License, or
    2017-10-12 08:09:09,995 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] (at your option) any later version.
    2017-10-12 08:09:10,007 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:10,044 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] This program is distributed in the hope that it will be useful,
    2017-10-12 08:09:10,057 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2017-10-12 08:09:10,068 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2017-10-12 08:09:10,106 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] GNU Affero General Public License for more details.
    2017-10-12 08:09:10,123 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:10,150 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] You should have received a copy of the GNU Affero General Public License
    2017-10-12 08:09:10,192 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] along with this program.  If not, see .
    2017-10-12 08:09:31,877 - DEBUG - CuraEngineBackend.CuraEngineBackend._terminate [244]: Attempting to kill the engine process
    2017-10-12 08:09:31,877 - DEBUG - CuraEngineBackend.CuraEngineBackend._terminate [250]: Killing engine process
    2017-10-12 08:09:31,883 - DEBUG - CuraEngineBackend.CuraEngineBackend._terminate [253]: Engine process is killed. Received return code 1
    2017-10-12 08:09:31,900 - DEBUG - UM.Backend.Backend._createSocket [214]: Previous socket existed. Closing that first.
    2017-10-12 08:09:31,943 - DEBUG - UM.Backend.Backend._logSocketState [174]: Socket state changed to Listening
    2017-10-12 08:09:31,955 - INFO - UM.Backend.Backend.startEngine [75]: Started engine process: C:\Program Files\Cura 2.7\CuraEngine.exe
    2017-10-12 08:09:31,967 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Calling engine with: ['C:\\Program Files\\Cura 2.7\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '-j', 'C:\\Program Files\\Cura 2.7\\resources\\definitions\\fdmprinter.def.json', '']
    2017-10-12 08:09:32,000 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:32,012 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Cura_SteamEngine version DEV
    2017-10-12 08:09:32,023 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Copyright © 2014 David Braam
    2017-10-12 08:09:32,032 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:32,033 - DEBUG - UM.Backend.Backend._logSocketState [178]: Socket state changed to Connected
    2017-10-12 08:09:32,036 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] This program is free software: you can redistribute it and/or modify
    2017-10-12 08:09:32,037 - DEBUG - UM.Backend.Backend._onSocketStateChanged [168]: Backend connected on port 49674
    2017-10-12 08:09:32,069 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] it under the terms of the GNU Affero General Public License as published by
    2017-10-12 08:09:32,091 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] the Free Software Foundation, either version 3 of the License, or
    2017-10-12 08:09:32,140 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] (at your option) any later version.
    2017-10-12 08:09:32,160 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:32,199 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] This program is distributed in the hope that it will be useful,
    2017-10-12 08:09:32,254 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2017-10-12 08:09:32,272 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2017-10-12 08:09:32,305 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] GNU Affero General Public License for more details.
    2017-10-12 08:09:32,358 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:32,381 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] You should have received a copy of the GNU Affero General Public License
    2017-10-12 08:09:32,419 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] along with this program.  If not, see .
    2017-10-12 08:09:35,681 - DEBUG - CuraEngineBackend.CuraEngineBackend._terminate [244]: Attempting to kill the engine process
    2017-10-12 08:09:35,682 - DEBUG - CuraEngineBackend.CuraEngineBackend._terminate [250]: Killing engine process
    2017-10-12 08:09:35,685 - DEBUG - CuraEngineBackend.CuraEngineBackend._terminate [253]: Engine process is killed. Received return code 1
    2017-10-12 08:09:35,707 - DEBUG - UM.Backend.Backend._createSocket [214]: Previous socket existed. Closing that first.
    2017-10-12 08:09:35,757 - DEBUG - UM.Backend.Backend._logSocketState [174]: Socket state changed to Listening
    2017-10-12 08:09:35,775 - INFO - UM.Backend.Backend.startEngine [75]: Started engine process: C:\Program Files\Cura 2.7\CuraEngine.exe
    2017-10-12 08:09:35,796 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Calling engine with: ['C:\\Program Files\\Cura 2.7\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '-j', 'C:\\Program Files\\Cura 2.7\\resources\\definitions\\fdmprinter.def.json', '']
    2017-10-12 08:09:35,840 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:35,854 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Cura_SteamEngine version DEV
    2017-10-12 08:09:35,874 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] Copyright © 2014 David Braam
    2017-10-12 08:09:35,875 - DEBUG - UM.Backend.Backend._logSocketState [178]: Socket state changed to Connected
    2017-10-12 08:09:35,888 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:35,893 - DEBUG - UM.Backend.Backend._onSocketStateChanged [168]: Backend connected on port 49674
    2017-10-12 08:09:35,939 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] This program is free software: you can redistribute it and/or modify
    2017-10-12 08:09:35,965 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] it under the terms of the GNU Affero General Public License as published by
    2017-10-12 08:09:35,985 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] the Free Software Foundation, either version 3 of the License, or
    2017-10-12 08:09:35,995 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] (at your option) any later version.
    2017-10-12 08:09:36,015 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:36,044 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] This program is distributed in the hope that it will be useful,
    2017-10-12 08:09:36,064 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2017-10-12 08:09:36,084 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2017-10-12 08:09:36,114 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] GNU Affero General Public License for more details.
    2017-10-12 08:09:36,139 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend]
    2017-10-12 08:09:36,155 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] You should have received a copy of the GNU Affero General Public License
    2017-10-12 08:09:36,175 - DEBUG - UM.Backend.Backend._backendLog [93]: [backend] along with this program.  If not, see .
    2017-10-12 08:09:36,468 - DEBUG - AutoSave.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles
    It doesn't appear to have generated a log event when the app crashed... the crash happpened at 8:16 am .  I literally just went to file / open file  and didn't click anything elese and the app crashes every time.
    I found the crash in windows event viewer.
    Faulting application name: Cura.exe, version: 0.0.0.0, time stamp: 0x597ef257
    Faulting module name: ntdll.dll, version: 10.0.15063.608, time stamp: 0x8274fd8b
    Exception code: 0xc0000005
    Fault offset: 0x00000000000b91f9
    Faulting process id: 0x2a64
    Faulting application start time: 0x01d342beaf0cb7e7
    Faulting application path: C:\Program Files\Cura 2.7\Cura.exe
    Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
    Report Id: 5358525d-cdf4-4948-973f-f39537f64f0e
    Faulting package full name:
    Faulting package-relative application ID:
    Fault bucket 120834980069, type 4
    Event Name: APPCRASH
    Response: Not available
    Cab Id: 0
    Problem signature:
    P1: Cura.exe
    P2: 0.0.0.0
    P3: 597ef257
    P4: ntdll.dll
    P5: 10.0.15063.608
    P6: 8274fd8b
    P7: c0000005
    P8: 00000000000b91f9
    P9:
    P10:
    \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERFC60.tmp.mdmp
    \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERFE26.tmp.WERInternalMetadata.xml
    \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERFE92.tmp.csv
    \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERFED2.tmp.txt
    These files may be available here:
    C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_Cura.exe_272b3f633e11bfadd64148baa0139dc9cd25db7_f2912f38_85bd16ae
    Analysis symbol:
    Rechecking for solution: 0
    Report Status: 268435456
    Hashed bucket: 27b8700e32b43625c1c9fe4a8f1fbe3c
    thoughts?
    Right. I thought it crashed due to the loading of the file. It seems that it's actually crashing somewhere while requesting the file loader. This is unfortunately in code that we have little control over (as we use third party software to handle these things).
    Instead of File->Open you could try dropping the file on the Cura window. This bypasses the file dialog, which seems to be the cause of the crash according to @nallath. Not a solution, but a workaround.
    this is working as a temp solution.
    I'm wondering what the actual cause is though. It crashes the same way if I try load a material profile etc.
    Cura uses a "toolkit" (or "framework") named Qt to handle the user interface elements. Opening the system file open dialog is part of that toolkit, and unfortunately the crash happens in that code. We have not yet figured out why it happens on some systems.
