Slow Moving Feeder - after new firmware upgrade
neo-ninja
Posted · Slow Moving Feeder - after new firmware upgrade
Hi Guys,
After some thoughts.
I just bought a new board (as the old one fried) everything is working great. APART from the feeder for filament. It is almost going at half speed, and i cant work out why.
I made sure i installed the UM2 not the UM2+ firmware.
The board all seems sound everything works apart from its slow. So it means when i eject filament it aprox does about half of it and when i put new filament in it takes ages.
Motor itself is good.
    The question is: what was previously installed on the new board?
    If in doubt, perform a factory reset with the correct firmware. Or have you already done that?
    The board should be brand new for a UM2.
    I have been playing around. I think maybe i hadnt pushed in the wire enough for the stepper as thats fine. But I have having a similar issue with the z axis, its moving almost exactly at half speed. I have tried all the connections again and no success.
    First thing to check in this case:
    There's a connector at the center of the board that is labeled "8/16 step". Take sure that there's nothing connected. If you accidentally plugged in the 5V connector (orange/blue cable) there - it would explain the symptoms...
    Oh really nothing should be plugged into the middle of the board? I copied all plugs like for like from the old board and that wire was plugged in.
    That's not what i said... :) Just don't plug anything to the 8/16 jumper, the white connector for the 5V fan is nearby. There are pictures in the assembly manual, page 65.
