Printer is an Anet A8 using Skynet 2.3.2 Yes it was assembled. Not sure what you mean by "If you print gcode does it also go the wrong way?" I am using Pronterface UI via Cura 15.04.6
Just upgraded to a E3D Bowden titan. Was working fine for months previously before the titan upgrade
gr5 1,872
What printer is this? Did you assemble it yourself? If you print gcode does it also go the wrong way? I recommend pronterface over cura for controlling your printer. It's free here:
http://koti.kapsi.fi/~kliment/printrun/
