Publish Monthly Summary of Cura Slices
burtoogle
Posted · Publish Monthly Summary of Cura Slices
I know that Ultimaker receives info from Cura when it is used (assuming that the user doesn't disable that option) so it would be interesting if some basic statistics would be published every now and again (e.g. monthly). It surely would be interesting to know things like the number of active installations, the number of slices performed, the amount of filament sliced, etc. for each version of Cura that provides the stats.
You have the data, why not share it?
I'm all for sharing it. There are some pretty cool insights. Let me ask around a bit. I do need permission for this.
We're already using the data to decide on what profiles we need to focus on, so you guys are already benefiting from it :)
