UM2 nozzle does not heat up any more
Massassi
Posted (edited) · UM2 nozzle does not heat up any more
My last print looked really strange. When I tried again there was no filament coming from the nozzle anymore. I also noticed that the nozzle was not 210 degrees as the display stated. I could touch it with my finger, it was not even warm. So if the nozzle is not warm, nothing comes out. So I guess that ether the temp sensor or the heating element is broken. But which one?
If any one can help, that would be great.
    Posted · UM2 nozzle does not heat up any more
    Ok the first thing I would do is check the sensor and it’s cable to see if there are any issues. It maybe that all the movement has cased it to split.
    The reason why I’d chase the sensor is that the printer starts to print. Which it shouldn’t do until temp has been reached.
    When you press print how long does it take to actually start to print?
    Also if you go to extruder temp in the advanced section what is the temp. Or when you go to move material it should give a temp reading whilst it’s trying to heat up.
    I’m interested what it thinks it’s reading at the start of the heating process.
    Also check the material setting on the machine. You should be able to access the material process in the machines process. Something may have happened where the temp is set incorrectly.
    I must say that I’m suggesting this from a UM2+ perspective so please excuse me if the menu setup differs from what you have.
    The last thing for now to try is use rep rap flavour in the machine setting for the G-Code in Cura. It over rides the machines own settings. (Learnt that recently)
    Let me know how it works out and I will try and help from there.
    I have found the problem. (after I completely dissembled the printer). It seemed that the nozzle was clogged. After cleaning it, the printer works great again. It remains strange that I could touch the nozzle.
    Thanks for your great advice.
    glad to hear it.
    maybe you have asbestos finger lol
    how long after the print stopped printing did you touch it. they can cool relatively quickly.
    one for the books
