If you are doing single extruder prints then then some of these are probably ignored. You could set them to 206,207,208,209 and then search through the gcode to verify that they aren't used and then you never have to worry about them again and can hide them. Of course for dual extruder prints these save a TON of time on the nozzle switching.
ultiarjan 1,223
Most of the complexity comes from the clever heating and cooling cura can do for dual extrusion. I agree there should be more levels of complexity / non-complexity in cura, and a simpler single extrusion profile for UM3.
