Posted (edited) · Prime tower not showing up
I recently got an UM3 ext. I'm trying to print out the gyro using a prime tower. When the gyro is loaded into Cura 3.0 and when I go into layer view the prime tower is not showing up. I'm not sure why, any suggestions?
    Posted · Prime tower not showing up
    Is it showing a shadow of where the tower should be in normal view? You can change it's location. I may have had this same problem but it was almost a year ago and I forget what I learned about towers in cura.
