kmanstudios 1,120
I have found that sanding is only good if painting; at least for me so far. But I did find that using an x-acto knife does a pretty good job of someone is decent at whittling.
You can also cover it with a clear coat of some kind too.
fbrc8-erin 296
You could try a program like MeshMixer, and make custom supports with minimal amounts of touching, like on this print (the post is a bit old, but MeshMixer is still around and something like this should work: http://www.extrudable.me/2013/12/28/meshmixer-2-0-best-newcomer-in-a-supporting-role/
Alternately, a little mineral oil might help shine the PLA up a bit where the supports were removed after sanding.
