I had the same problem a cuple of weeks ago. What is the value of infill overlap in cura? I had to rise this value, only a 1 or 2 % and the problem was gone.
It is currently at 10%
I have tried adjusting that as well. I will give it another go so be sure.
Note though that the problem does not appear to be with the infill. The innermost and outermost perimeter of the three looks just fine, it's the one in the middle that is printed at a faster speed that shows under extrusion.
Though it is possible that the innermost perimeter is part of the infill and as such should overlap the one in the middle.
This is a more close up photo. There also seems to be quite a wide gap between the lines even on the second layer. Almost like the first layer when the nozzle is slightly to high.
UbuntuBirdy 52
