Var/spool/cluster is reserved for print files so you can re-print objects from within Cura Connect, and also the print-queue is here when Cura Connect is functioning as a print job spooler for multiple printers.
- 1
Thanks for the reply. Been double checking my root partition, and it has remained at 64%.
On 3/30/2019 at 9:45 PM, fbrc8-erin said:Contact your reseller. You're going to need to re-image the Olimex board from a microSD card.
Thank you, this worked for me. I was able to re-image the Olimex board myself using my microSD card and files that my reseller sent me. I then upgraded to the latest firmware, redid my calibrations, and everything was back to normal.
SeanTapscott 3
It should be mentioned that I did upgrade to the latest firmware version, and I'm not convinced that the problem isn't still going to occur. Did some kind of file system management cleanup utility stop working in the latest firmware version that is causing the root partition to fill up?
Mine was at 57% earlier, now it is at 59%, so it may be climbing, or it may be normal, not enough data yet.
root@ultimakersystem-ccbdd3001d4c:~# df -h Filesystem Size Used Avail Use% Mounted on /dev/mmcblk1p2 941M 474M 336M 59% / devtmpfs 471M 0 471M 0% /dev tmpfs 504M 0 504M 0% /dev/shm tmpfs 504M 1.4M 502M 1% /run tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 504M 0 504M 0% /sys/fs/cgroup tmpfs 504M 0 504M 0% /var/lib/apt tmpfs 504M 0 504M 0% /var/cache/apt tmpfs 504M 4.4M 499M 1% /tmp /dev/mmcblk1p3 2.7G 39M 2.4G 2% /var/spool/cluster /dev/sda1 29G 4.1G 25G 15% /media/usb0 root@ultimakersystem-ccbdd3001d4c:~#
Are we supposed to be using that /var/spool/cluster for the root, or is that reserved for print files?
