Sorry to read that you're having a difficult time.
I've only had my (kit) Ulitmaker a few weeks but I have some loss of extrusion experience already (far too much,in fact).
The first was obvious - the bowden tube had come out at the hot end. Eventually fixed (with the help of advice from this forum) with a new retaining collar (collet). This problem may have been largely my poor assembling - and, perhaps, a substandard retaining collet.
About a week later, lost extrusion again. Bowden tube OK (both ends), absolutely no sign of leakage.Looked up the Wiki and followed the advice to try 240C, 250C. No good. Searched the forums and found a note from Daid suggesting 260C - and, once the nozzle was clear, then making something at 260C. Wound up to 260C, waited a couple of minutes, and then pushed the filament by hand. After a while the nozzle coughed and spluttered and material started coming out, after another minute or so it looked as though it was coming out at the right rate. Given the strong words in the Wiki about only a few minutes at 250C I wasn't keen to continue at 260C - which may well have been a mistake. Dropped the temperature to 210C and all seemed well. Started making something, all fine for quite a while then extrusion stopped again. Once again Bowden OK and no leaks. Couldn't push filament through by hand.
Fully disassembled the hot end. Very hard to see into the nozzle. Put it into our electric oven inverted at 250C for quarter of an hour and black stuff came out. But not clear. Could find nothing to push through the 0.4mm hole and have ordered some 0.3 and 0.4 drills (with plain ends so I won't have to put a cutting edge through the nozzle).
Reassembled, but broke the brass tube when doing so. Yes, I was using a wrench on the PEEK. A complication is that the the PEEK lower end had swollen and kept jamming in the Aluminium plate.
Fed up with this I've ordered a new nozzle, PEEK and brass tube.
In the meantime I've filed down the swollen PEEK so that it no longer jams.
Once the drills arrive I'll clear the nozzle (using a butane torch) though without being able to clean it thoroughly internally I'm worried about residual carbonised PLA. If (when) I have this problem again I'll follow through with the 'make something at 260C advice'.
Sorry that I can't offer you an easy solution to your problem - only the consolation of knowing that you're not the only one suffering!
gr5 2,334
I have never had this problem so I am not the best person to ask but I have 2 theories:
1) Maybe there is something wrong with the thermocouple. Maybe the temp is much lower than you think. Maybe try setting the temp to 101C exactly and see if it boils a drop of water? Maybe try 260C? (careful as you shouldn't let peek get to 300C).
2) Maybe there is a piece of metal or wood chip in the print head. Look in the feeder and see if there are any splinters - take the filament out and use a flashlight and look carefully for chipped/broken wood. Maybe you work in a dusty room? I think it's time to heat the head and unscrew the nozzle - perhaps by hand with an oven mitt? I doubt you will break it if you don't use a wrench. Then heat it up enough to burn any potential wood or dust in the nozzle maybe with flame?
Hopefully someone who's done this will reply.
