Hi, Thanks!
I have leveled the build plate closer and did a test print with a smaller object,. that went fine.
I'm using layer height 0.06 and initial layer height 0.27 mm, all line width at 0.4 Would you suggest to change? Also should I change the print speed? I left it at 50 mm/s.
Thanks again!
DidierKlein 730
Hi and welcome,
I would say that you can maybe level your plate a tiny bit higher (closer to the nozzle). And i you apply glue or something make sure you apply it smoothly on the whole area.
You can also print the first layer a bit hotter, by the way what is the first layer height?
