I have windows 7 and use cura 3.04
Could your press winkey+r, and type %LOCALAPPDATA%\cura and press enter.
An explorer window should open, containing a number of folders and stderr.log and stdout.log. Those two files should contain a hint to why Cura is crashing. Could you zip them up and post them somewhere?
1
I dropped them in a wetransfer link
Thanks. That log does not indicate that Cura crashed on the last run. Did it?
I meant to say: please make Cura crash by switching printers, and then zip up those logs.
Last time it also crashed, but I cleared the logs reinstalled and let it crash again to make sure it should be the right logs now. They can be found here
This new log indicates that the crash happens while loading/displaying ("binding") the texture for the buildplate. That suggests the driver is doing something rather unexpected. Do you have up-to-date drivers for your FirePro M4000 GPU?
1
I had looked at this before and it always said my drivers were up to date. Because of you I looked a bit closer into this and it turned out my drivers were so old they did not know how to update themselves... But thanks to you it is now solved!!!
thanks a lot!
1
ahoeben 1,890
What OS do you use, and what version of Cura do you currently use?
