Posted
(edited)
· Ultimaker Original - dual extrusion
I made the modification so that it is easier to level the nozzles.
I have removed the Corrugated spring washer.
The lock nuts keep the wooden parts of the printhead together.
The lock nuts have just been tightened, allowing the thumb bolts to rotate freely.
In order to enable the assembly of the cooling fan I made two spacers of washers.
The cooling fan is attached to the aluminum plate from below with an 8 mm bolt (I'm not entirely sure, but it can also be a 6 mm bolt or a 10 mm bolt).
Adjusting the nozzles:
Pull the bowden tube up slightly.
Raise the square nuts.
Adjust the nozzles by turning the four thumb bolts.
If the nozzles are correct leveled, the peek is clamped between the wooden plate and the aluminum plate by turning the square nuts downwards.
This also fixes the nozzles.
Push the bowden tube downwards so that it presses firmly against the teflon tube.
Bold = Ultimaker parts, Bold/Italic = added parts
That is all ;-)
Edited by TheSeend
1
TheSeend 4
That is all ;-)
Edited by TheSeendLink to post
