That would be too easy!
Joking apart, that works just fine. A little embarassed for not having thought about that ^^'
1
On 1/20/2018 at 1:15 PM, Crisoberillo said:That would be too easy!
Just to let you know that you are not alone 😓
Yes, filling in 0 for Z works, but ... having a shorcut key to do this would simplify life so much, especially when you often use standard objects (via the suitable plug-in) to then add modifiers to parts of the print. You don't want those modifier objects to always be on the build-plate, so you have to turn off the "automatically drop to build-plate" option, but then for the actual printed parts, you do want them on the build-plate, so ... a shortcut (may I propose CTRL-SHIFT Z) would really be appreciated.
burtoogle 510
How about selecting the model, and the move tool and entering 0 into the z field?
