I agree with geert_2 - that's what I always do. Just a small 1cm by 1cm cuboid of the exact same height as the bishop will do. And place the other object in a position such that fans are cooling your bishop while the other object is being printed. Even just 3 seconds away from this part should give it plenty of time to cool.
I have a 30cm_cube.stl file I keep handy. Cura lets me adjust the x,y,z scaling in mm (you can do % or mm scaling). I make it the same height as the model and adjust the x/y to be about one fifth the height so that it's a stable part and won't fall over. In other words if the part is 50mm high my base is 10X10. If the part is 10mm high I could go as low as 2x2 (probably would do 5x5).
geert_2 557
I have also noticed that when the nozzle is just waiting outside of the model, this may cause little defects due to the nozzle leaking, or due to its "take off" from the model, and due to the no-flow in the nozzle, which causes higher temps and thus more liquid material. Also sudden changes in layer area show up due to huge differences in cooling time.
That is why I usually print a dummy model next to the real model, when printing time is too little for good layer cooling. Instead of using the minimum layer time feature. Ideally, the dummy model would have the inverse layer area of the real model, so cooling time per layer is identical. This doesn't matter for big objects, but it does for very small ones. So what you could do is subtract this model from a cylinder, and use that inverse cylinder as dummy? Be sure to design a good bottom plate to get good bonding to the print bed (for example: something similar to a brim, but manually designed into the model).
For best results on small objects, layer printing time and material flow through the nozzle should be steady through the whole printing process.
Another option might be to print enough models at the same time.
