yellowshark 153
Great you fixed it - I was going to say and I still will, for your benefit. I have been using Solidworks to model and create stl files for over 4 years now and have NEVER had a faulty stl file produced. As they say you get what you pay for.
- 4 years later...
I tried everything but it still wouldn't work. I tried all you guys said but nothing.
1
Please post your project file so we can see what is going on. In cura do "file" "save project..." and post that file here. It will contain your model(s) and your machine settings, profile, and your settings overrides.
gr5 2,210
I see you have infill at 99% yet it's hollow inside.
Is it important to be hollow inside? Basically you gave the walls a thickness. Which I hope is what you want. Probably what you want. But maybe you didn't also give the ceiling a thickness?
Look at the part in xray view as well. If you see any red then that's the problem right there. Or if the ceiling is thinner than .1mm (your layer height) then that would explain the problem.
If you see red then you can fix the model in cad - it has either not enough walls or too many walls. or that top wall is infinitely thin (and it plans to print it infinitely thin, lol).
Or you could try fixing the model with a free service. But it sounds like you know CAD so maybe fix it in your cad software.
