On 1/31/2018 at 10:28 AM, nallath said:Could you provide the log files?
here are the log files.
You seem to have connected Cura to a printer manually (using the "Add" printer in the Connect over network dialog), pointing to the address 127.0.0.1. That specific address always points to the computer Cura is being run on, not to the printer. So instead of trying to access a printer, Cura is trying to access the computer it is running on as if that computer were a printer.
Edited by ahoebenThank you I understood the problem!
It's solved!
nallath 1,124
