This model can have layer lines and print lines, I think. It gives it a nice "industrial look".
1 hour ago, geert_2 said:This model can have layer lines and print lines, I think. It gives it a nice "industrial look".
He actually sent me a pic of one in its final stages and it does look like that! LOL
This is a new project for my brother. I have this ready to print:
It is part of a heat exchanger unit. When finished it will be 11.5" in length. I may get this one done to take to the Netherlands. That is usually the kiss of death for me though since, as soon as I mention something like this, all kinds of hell rains down upon the project. But I shall give it a go. I think I will print it in Fillamentum's Rapunzel Silver Extrafill. Fingers, toes and eyes crossed on this one.
Then I will print this. It is not ready as it is missing a few parts that he will put in and resend, but I wanted to see what he thought of the look. For both of them, I took his Inventor Files and thickened them so that the walls and such would print and created the cutaway look for the machines.
At this stage, each one is designed as a single print and no assembly required. By rotating and angling the object, I can make it slightly larger than the spec'd dimensions I am showing.
Edited by kmanstudiosOh good luck with that. Thats something i could never print without cuts. Should look great when done though! Would look great in metal too!
Edited by cloakfiendYeah, I am kinda wondering how that works out myself. I asked for things to challenge the printer.....hahahahahahaha.
He just updated the models with all the parts to them such as the retaining bolts. I have the top image of the cooling unit sliced and ready to print when the printer gets finished with what it is working on now tomorrow afternoon.
That one will take three days to print alone.
The bottom one with two of the cooling units (twice the printing on that) plus the framework and additional piping will be interesting to see how long it takes to slice and print.
The Cooling unit alone will be 11.5" from end to end, but it will printed vertically. The other one will really fill up the buildplate. I mean not really max it out. But I am glad I have the extra room on that thing to print with. It would be interesting to make an assembly model out of it and really get in there and treat it like a real kit. That would be a gazillion parts....yeesh!!
Since he updated the model with all the doodads and stuff...... It is proving to be hell for Cura to slice it. It is really a lot of stuff going on there. I just may have to break it up to get to just slice.
Revised with all the doohickies....
This one sliced just fine and is a 3 day print.
I will figure it out when I get back from a bidness trip. For now, I am just letting the full model sit and slice while I am in bed.
Cool. What is the purpose of these models? To show the internal components? Or as part of a scale model for a new plant?
I have worked in a huge chemical plant long ago, in the port of Antwerp, so I have seen and operated quite a lot of distillation columns, heat exchangers, valves, coolers, pumps, and stuff. These models look really realistic, with all the bolts and flanges that I would expect, and even the eyes for lifting it with a crane.
Are those little tubes hollow all the way through? Wonder how that is going to come out of the printer, and how you are going to get the support material washed out of them...
Just decimate it to about a million polys and you should be fine! 2 Million if your feeling lucky!!! I wouldn't go much above that personally.
Lol
47 minutes ago, Brulti said:
ROFL!!!
Wow, that's impressive.
OK, I did a couple of mods. Just for the heck of it.
In the big one...
...I replaced some of the tubes, such as the bundle of the cooling units in the center and a few pipes around the edge to keep the slicer from making useless interiors that cannot be really seen with solid cylinders. This had a radical effect of making the print time go from 204 Hrs to 190. While only 14 hours difference, every moment counts.
Just curious but what is the poly count on your stuff. I usually stick to about 70,000- 700,000 for small - big models. slice quickly and print ok. I also aim for 7-12hr prints regardless of the model. But recently i had to reprint my Giger print and internal infill added 9hrs from 36 to 45 hrs. But it did print perfect compared to the original which had major holes and distortion in it that I spent hours filling due to the lack of support. Never again!!
Because I have pretty much abandoned poly modelling I have very few hard edge models which Is a shame. I must do more robotic stuff! Seeing all your straight edged stuff is very refreshing due to the simple but highly detailed nature of it. Low poly versions of the stuff you are doing would be totally useless and defeat the point.
Keep it up, and good luck with the print!
Edited by cloakfiendMy Poly count will greatly vary, but I do try to go no more than 2.5 million. That is for a really crazy model. I also make a lot of models that are hollow. That doubles the count, so if it were a 2.5 Million as a hollow object then a solid would be around 1.25 million.
It also depends on how much support has to be made and how thin I tell the line widths to be. These two models are really not that big in poly count. It is more about all the little nooks and crannies and tight areas it has to work with. Also, these models are actually models that were made for manufacturing and there for tubes are true tubes and not solid cylinders and such. That adds to a bit of time as well. And, I am printing really, really big stuff with sometimes really tiny details like this one:
That thing fills up the print area with barely enough room in height.
But here you can see that it is hollowed out with tubes and holes for LEDs, Fibre Optics and Side Casting Fibre Optics. So, that adds an enormous amount of time and polys for printing.
The Throne of the Nautilus King is that way as well:
My fractal stuff I try to keep at the above mentioned maximum. And the hollow thing is so that I can control transparency. But the Supports on this one ate me alive both in material and time.
If I push the line widths for the 0.4 nozzle to about 0.64 I can print a single wall with the model actually having two physical walls. This gives me a decently strong print with a huge amount of transparency with the right filaments. I have printed a second of Julia's Flower (The print above) with just the one wall. It is also a slight redesign. This one was printed with 2 walls for a total thickness of 4 printed walls. When I get the other print photographed, I will put it up so you can see just how transparent it can get. But, wow, it eats support like you would not believe.
Edited by kmanstudiosThose things are impressive. I could so use those sculptures for yours for my RPG games...
8 hours ago, Brulti said:Those things are impressive. I could so use those sculptures for yours for my RPG games...
I do not understand.....do you mod your games or make your own?
You should see some of the weird sculpts I have done via fractals, such as those. I do sometimes add stuff to complete the look, but it is all mostly fractals. Believe it or not, most of those are a bunch of fractals I threw together when something pinged in me warped brain. I just see stuff all the time in shadows and patterns and such. I am completely visual.
For instance, my bug helmet is a bunch of fractals with a bit of Kirbyesque modeling to complete the look in the eyes and chin/mouth region. And, the bug helmet and the throne image above are related in concept.
12 hours ago, kmanstudios said:I do not understand.....do you mod your games or make your own?
I do pen and paper RPG, not computer ones. So, there's not much of a visual aspect to it, except for pictures used from time to time to show some stuff, or when playing in well known universes like Star Wars, and your sculpts, like the throne one would add that stunning visuals to a game.
"You finally arrive at the end of a tunnel. It opens up to a vast cavern dimly lit by phosphorescent fungi. In the center, sticking out of the murky waters, you see the Throne of the Sea King!"
Then I place your sculpture on the table, and I'm sure that all my players would open their eyes wide in astonishment.
Oh...I see.....well, then, feel free to use them, but please do not distibute without credit.
And, the Nautilus King is smoking a ceegar
Thank you, and I wouldn't dare distribute anything without giving due credit.
kmanstudios 1,120
Thanks
Coming from you, that means a lot. ![:) :)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
