Hi gr5,
Now that you mentioned it, I noticed that the nozzle is visibly further to the right in comparison with the original UM2 hot end.
I'm guessing I need to adjust Cura for this? I don't know how. Do you?
Thanks
Hi gr5,
Thanks
Well the head itself can move to the left until it hits the switch and clicks and no farther. And it can move all the way to the right until it stops moving. You can push the head around yourself. mentally mark where the extruder is at those extremes - is it over the glass at both extremes or does it go beyond the edge? If it doesn't go beyond the edge of the glass then no worries - just let it print a bit to the right and put the dimensions of the printer back to the way they were.
The glass is bigger than the "print area" as you will see. On the um2go the glass is a bit smaller than the print area on the left side and you can print past the left edge of the glass if things aren't calibrated correctly.
On 2/13/2018 at 10:18 PM, leonardo-aguiar said:Hi gr5,
Thanks
Better to redesign the mount rather than taking the stock E3D design, as they are old, i kinda solved this for my V6 by reworking the wholething
3 hours ago, rajilpahuja said:Better to redesign the mount rather than taking the stock E3D design, as they are old, i kinda solved this for my V6 by reworking the wholething
That sounds interesting...what did you do?
1 hour ago, kmanstudios said:That sounds interesting...what did you do?
I made a mount like the original ultimaker 2 with modifications to fix the E3D head V6
On 2/16/2018 at 6:24 PM, kmanstudios said:That sounds interesting...what did you do?
Have a look just an idea of what can be done
Edited by rajilpahuja
This is how we do it ?
That is cool. A pic is worth a thousand words to me. Thanks!
gr5 2,230
I checked the web page and UM says UM2 dimensions are 223X223. That's not necessarily the official default in cura though.
Is your extruder physically more to the right than the original feeder was? The feeder is normally slightly to the left - maybe 1cm?
I guess I'm wondering how much to the right your print was located.
