It looks like your bowden isn't in all the way in maybe. Check that carefully and also make sure your third head fan works.
So I took the third head fan out, and lo and behold out fell a rogue machine screw that had presumably been stopping the fan from turning properly. Got a test print running now so my fingers are crossed that that was the issue.
Thank you! Hopefully I won't have to get a new coupler after all.
[Edited just to say that my printer is now printing perfectly again :)]
Edited by CatG
geert_2 557
I do not have an UM2+, only the UM2 non-plus, so this is just general guessing.
It looks like the heat travels up too high in the nozzle. So maybe you first need to check if the little fan works well? The one blowing on the filament and nozzle, which should prevent the heat from traveling upward? There could be strings of filament stuck in it.
