JohnInOttawa 103
Thanks for the suggestion. I had considered doing just that, of course thought it would be more straightforward, and stronger, to do it all together.
John
John
Another option might be to print the thread a little bit too small, so it does not fit. Or print the model without any thread. Then warm it up in an oven (only if electronically controlled), or on the build plate to about 70...80°C, screw it on the equipment immediately, and let it cool to room temp. In this way I have made difficult designs fit around clamps, although without threads. Expect it to take a few trials, or try on obsolete equipment first. Make sure your photo equipment has metal threads, no plastic ones.
Thanks. I was hoping to learn that my technique with the support material was somehow flawed and there was a setting fix. Sounds more like it's a shortcoming to work around.
Thanks again and all the best
John
Well, of course there may exist better settings; it's just that I don't know them. And I don't have an UM3 with supports anyway, only single nozzle UM2s.
Small threads will always be difficult due to the layer lines which distort the shape and cause sort of "derailing". I also found it almost impossible to machine threads in PLA (I tried M3, M4, M5), due to the low melting temp. Even when taking very much time (+10 min) to slowly cut the thread manually, it still melted, and it was not strong enough to fix the screw later on. I think most people will try to avoid threads, and use other methods. That is the background idea for heating and making the whole model softer, and then forcing it on the other part and let cool down. This works well for rough shapes like clamps, but I can imagine that it may not be optimal for finely machined parts like photo equipment. I guess it will require trial and error. If you would find a good solution, please let us know.
By the way, any models in PLA will become soft and distort anyway, if you leave them in your car in the sun, even on a mild spring or autumn day.
The first image below shows the clamp which had to fit over a big glue clamp, so I heated it and forced it over it. The thin colored plates are supports to get it printed on my single-nozzle UM2. It are separate plates for easier removal.
If you don't mind a bit of uglyness, you could also use external screws to hold parts together, as shown in the other models below. These are clamps for laboratory equipment. It takes less time to design and print them, than to search and buy.
I've had a lot of luck printing internal threads, even down to M3 size on my UM2+ (.1mm layer height, PLA, default settings). The caveat is that the holes need to be oriented vertically along the Z axis.
The threaded connection is quite strong for my purpose, which is an electronics enclosure. There are holes for M3 bolts in the lid, and pre-printed threaded holes in the box. You can just screw in M3 bolts without worrying about nuts/nut traps so it's very convenient.
I can definitely see how it would struggle though if they weren't vertically oriented and had support material to deal with. @geert_2 I agree that tapping PLA does tend to create a mess though.
yellowshark 153
t1. cut the model horizontally in half. 2. Prin both halves, I assume the adaptor will be supported by the plate. 3. Use the right glue and glue the two halves together.
Edited by yellowsharkLink to post
