Indeed, Cura being free is a huge benefit. In my opinion, it's easier to set up for your printer, although once you have S3D set up, it's pretty easy to use as well.
In my experience, S3D is a bit better with support in that it's easier to remove and leaves a cleaner surface. I haven't tried all the settings in Cura, however. I am just talking about the default support settings. Cura does better brims, although I think the latest version of S3D has improved that. One big advantage of S3D is the ability to customize support. I hope Cura gets this feature someday, and then I probably would just use Cura all the time.
I recommend you use Cura and become familiar with 3D printing first, and if you want to try more complicated settings later you can try S3D.
Edited by rowiac
ahoeben 1,968
There are things S3D does that Cura does not do. There are also things that Cura does that S3D does not. And then there’s a lot the both of them do differently.
It comes down to preference. One thing Cura does that S3D doesn’t really is let you try it out for free.
