I would rather see these files as a good addition to the UM2 git repository. Maybe somebody with commit rights can add them to https://github.com/Ultimaker/Ultimaker2/tree/master/1546 ultimainboard V2.1.4
That would be a good idea, if the UM team wants that. I can also provide the source documents for the docs
- 4 months later...
Hi @jonnybischof, or anyone, I'm having trouble deciphering the pinouts and how they all relate to values in pins.h? For example, LED J15, is defined as pin 8 in pins.h.
On the schematics linked to, the BC817 leading to the signal has PH5 at the end of it, which when I look at the big Mega2560, looks like it's pin 17? How to I correlate the different values?
Specifically, I'm looking for details on the signal pin for J9, and J24-J26 (I'm hoping to add auto levelling on J9, and a third extruder to my UM2 for J24 and J26, per the Ultimaker2 Diamond on the reprap wiki, for a multi material experiment I want to run)
Edit: I'm an idiot, I found what I needed here. Saving for future reference:
https://www.arduino.cc/en/Hacking/PinMapping2560
Edited by halfie
Additional information
tinkergnome 834
6 hours ago, halfie said:I found what I needed here. Saving for future reference:
I often use this pinout picture as a reference, it includes the pin numbers from the Arduino IDE / pins.h:
1
jonnybischof 59
I would definitely add PDF and ZIP to the list. Doesn't matter much to me since I'm not really active on this forum anymore. But this just belonged here
