pause at height - whislist:
cajodo
Posted (edited) · pause at height - whislist:
I know, Chritmas is over, but
becaus I am often using the
Erweiterungen -> PostProcessing -> G-Code ändern -> pause at height (plugin)
5a99758aaba17_Bildschirmfoto2018-03-02um17_01_32.thumb.png.eda3e37749e0de53b07d01bfb13d60de.png
for inserting something into the print. Often I miss the correct layer -> I think because of the wrong layer calculation (my previous post)
I want to see the correct Z-Position in the LayerView, to insert the correct values into the pause at height dialog.
And maybe, I can insert the LayerNumber into the dialog, an it calculates the z-height by itself.
like in the TweakAtZ:
5a99758c5c309_Bildschirmfoto2018-03-02um17_01_55.thumb.png.3a1f804381e292069b962c573d6d00d9.png
and a G-Code command for making the Ultimaker BEEP, when the layes is reached, will be the greatest.
AND / OR displaying the time, when the "event" at the Ultimaker will be reached will also be great,
AND Displaying the actual Z-height in the Ultimaker-Display... will make my life easier.
THX Carsten
Edited by cajodo
    Posted · pause at height - whislist:
    If you want to display the z-height you need to have a look at the tinkergnome firmware (um2 - 2+)
    https://github.com/TinkerGnome/Ultimaker2Marlin/releases
    Regarding issues it seems it is more visible to the awesome team of devs (and community members) on github
    https://github.com/Ultimaker/Cura/issues
    Now, with the "new" firmware I can compair the printed z-height
    I have tested the following example:
    I want to insert someting into my print.
    CURA settings: first layerheight = 0.3 mm layerheight = 0.15 mm
    The last "open" layer is 52, the next layer 53 closes the hole.
    52 is the last chance to insert something.
    calculating the height:
    the fist layer is 0.3 mm
    52 - first layer = 51 layers to print with 0.15 -> 7.65 mm
    7.65 mm + first layer 0.3mm -> 7.95 mm
    7.95 mm should be the correct for "Pause at height"
    But you had to enter 7.8 mm (7.95 - layerheight 0.15) , to stop at the last layerheight to enter something. Then while printing (in real life) 7.95 mm is displayed when the pause is done.
    maybe this corresponds to this:
    WHY?
    Does anybody know?
    - Carsten -
    Edited by cajodo
    I don't have any great answers, but I can say my experience parallels your own. The best way to use this plug-in is to do a test print, see what happens, go back, retweak it, edit g-code by hand, etc.
    Saying "layer number", or being more explicit about where the stop will happen, would be a huge upgrade to a useful tool
    Sorry, i have an exact opposite opinion... Why the "layer number"?
    If i have a need to pause a print at a certain point - i always know the exact z-position. Who cares about what layer this is?
    Why should someone want to calculate a layer number every time?
    The layer number will change every time i modify the layer height, but the z-coordinate is always the same - that's much more convenient, reliable and save.
    If i don't know the z coordinate (for whatever reason) - it would be nice, if the layer view would display the z-position, ok, but that's it.
    Perhaps i understand something completely wrong - i just don't see a use case where i need a layer number as a pause "position"...?
    (all above is IMHO of course).
    @cajodo One weird thing is, that the post processing script subtracts the first layer height to calculate the current height in the gcode. There's a comment:
    # use offset to calculate the current height: <current_height> = <current_z> - <layer_0_z>
    If i were you - that's a question i would ask the developers on Github at the next opportunity.
    Quote
    In some cases it's unnecessary in other cases it absolutely makes sense to handle the pause via layer-numbers.
    For example:
    I often make two-colored nameplates (with one extruder). The base-plate is 0.8mm high, the letters in another color are 0.4mm.
    Now I know, the pause had to happen at the end of 0.8mm (the 4th layer in my case).
    But if you have a unknown model (let's take this for example, which could be a nice multicolor print with one extruder) it is much easier to scroll through the layer view and say: "o.k. at layer x is the first color change on layer y the next", and so on...
    • Thanks 1
    Ok, with other words - one can use the layer view as a tool to measure the model...
    I had never thought to use it this way... thank's for the explanation - i accept this as a valid use case :)
        • 1 reply
