Cannot really say much without knowing what your settings are, eg temperatures print speeds, overlaps etc. The tall thin piece will probably be due to minimum layer print time - ie. it is so thin there will not be enough time for the layer to cool before the next layer printed - of course the pic is not of the complete model so that is more of a guess than an absolute.
Turns out a big problem was with the print core. I switched it out for my other AA 0.4 and it worked much better. So I switched it back in and did a few cold pulls and it improved it quite a bit
yellowshark 153
