Skipping on layer 74 using cura, doesnt skip using other slicers
tobighst
Posted · Skipping on layer 74 using cura, doesnt skip using other slicers
on layer 74 it stops printing and skips to the next layer, i know this because i imported my gcode into a model viewer and i can see where it just skips the layer. if i use slic3r for example it doesnt do that. ive tried uninstalling cura a few times and nothing has changed. how do i fix this?
cura dragon.gcode
slic3r dragon.gcode
    Indeed there's a missing layer in that gcode.
    Which version of Cura is it?
    Anything special in your settings?
    This model should slice with no issues
    The first thing to check is to look at the model in "xray" mode to see if there is any red color near "layer 74".  If so then your model isn't manifold.
    Even if you see no red I would try sending the model through the netfabb free repair service (you have to create an account but it's quick and free).
    netfabb free repair service is here:
    https://service.netfabb.com/login.php
    Did you create this model?  If so what cad software did you use?  There's lots of ways to make sure your model is manifold in the future.  In particular sketchup is really bad at making manifold models but there are lots of great tools and tricks to overcome it's limitations.
    @diderklein nothing special in the settings, i even switched to default settings and that didnt help.
    @gr5 this model is off of thingiyverse and the model hasnt had troubles for anyone else.
        • 6 replies
