Before you print anything look at the part carefully in layer view. Please show us the problem in layer view. I don't think there is need to show us the actual print since we can't really see anything anyway but a blue cylinder.
Did you create this model yourself? If so did you use sketchup? If so then I think I know what the issue is.
Nicolinux 288
what do you mean? What does happen? What doesn't work?
Sadly the photos are too vague and one can not tell what is wrong with the print.
Which printer do you use? Which filament do you use? Which slicer do you use? Is it Cura? If yes, which settings did you enable?
