Hello,
1- It should be fine, it worked before
2- The filament is the original shipped by Ultimaker, you helped me in another post and said it should be 2.89 Correct?
3- Temperature is 215, layer height 0,1 , skin thickness is ???, print speed is 50
I dont think im trying to print to fast, because it also happens that it just stops printing and the filament is stuck in the part above the nozzle. I have cleaned this after dissassembly, but it didnt help.
I cleaned it by heating it and also used (THF) for solving the stuck PLA. all seemed fine after.
4- Printhead should be fine. And extruder feels fine to me.
Everything has worked fine a few days ago, i printed the OWL statue on the thingiverse website, and it came out like it should, except for some under extrusion on like 2% of the whole model, so no big issues there.
I think the ussie lies with Filament getting stuck, but i dont see why, because it worked before, and its cleaned as good as i could. At the moment the filament is so stuck i cant get it out even with pliers.
illuminarti 18
There may be something about your particular Bowden tube, or how it is installed that's making it pop loose. Some people have had problems - some lots. Personally, I've never seen this happen on mine.
If the cabling to the thermocouple pops off, don't keep printing. Not only will you get bad results, but you'll quite possibly damage your print head.
Something is causing you to generate high pressures within the Bowden tube - which basically means you're pushing the filament harder and faster than it can escape out of your nozzle.
A few things to consider:
1) You might want to check how your feeder drive is assembled, and in particular what the tension is on the spring on the back of the filament clamp. It should be roughly 11mm long - the spring shouldn't be totally compressed. Part of the problem might be that you're grabbing the filament so hard that even when pressure gets quite high, it doesn't slip at the extruder end, but instead has to break something else.
2) Check your filament diameter. Is it comfortably less than 3mm throughout? When the extruder drive is open, can you slide fresh filament into the Bowden tube easily by hand, with virtually no resistance? If the filament is too thick, it will get stuck in the tube, and the extruder may keep pushing until it pulls the tube out.
3) What temperature, layer height, skin thickness, and print speed are you printing at? If you try to print too fast, the nozzle won't be able to keep up, and pressure will build up on the filament.
4) If you heat the print head, lower the bed a bit, and turn the extruder drive gear wheel by hand, what does it feel like? You should feel a little bit of push-back if you turn the edge of wheel more than one or two mm per second. But you should see continuous extrusion from the nozzle, and shouldn't feel a solid barrier. And you shouldn't be able to pop the Bowden tube off by hand.
Now that the tube has started to come loose, the ends are probably damaged, so you may want to trim the last few mm, and resecure them - perhaps with some additional sort of clamp. But it would be good to know what is causing the frequent pop-offs. I have no extra clamps on mine, and have never had it happen.
