Hello Didier and thanks for the reply!
The feeder is a standard Ultimaker 2 feeder if I'm correct. We don't have the 2+.
The Filament itself is rather old for as far as I know, It snaps after bending a few times (Parts that have been near the heater that are cooled can be snapped by bending it once for ex. the rear end of the filament after changing the material). The PLA 2.85 mm filament is from Ultimaker itself. ( Or atleast it has the logo and brand name of Ultimaker on the coil so I'm guessing they came from them.)
I'm printing at 240 degrees Celcius (Nozzle) and 60 degrees celcius (Bed). 60 mm/s. 0,1 mm layer height. 0.8 mm wall and top/bottom thickness. 20% infill density. Using a brim buildplate adhesion with a 8,0 mm width.
When I push the filament trough manually it goes pretty smoothly. Did this several times already and that seems to work fine.
DidierKlein 730
Hi and welcome,
I think the white plastic is simply red filament but very small quantities of it (as it's blocking).
What kind of feeder do you have? (Ultimaker 2 or 2+?)
What brand of filament? Is it old? Settings?
Are you able to push filament by hand and extrude? (Like you would do for atomics)
