kmanstudios 1,120
2 hours ago, tinkergnome said:That was not me who told this to you, but it sounds like a good idea
Hmmmm....I wonder who it was...it was a good suggestion. I do not use the method you just described with the stepper motors running either though.....
pbackx 11
I had to get used to this system too. But once you get the hang of it, it's pretty easy. The only thing I haven't gotten used to is the fact that the spools are on the back of the printer, so I now have my printer with the side facing forward on the desk.
* Make sure that the filament is as straight as possible. Sometimes it can be pretty curled, especially the last part of a spool.
* I lift the tensioner with my thumb or index finger (pull the white knob upwards)
* Push in the filament until you feel the wheel is gripping it (no force is needed for this, just move it upwards)
* Release the tensioner
After some practice this takes me at most a minute
Edited by pbackxLink to post
kmanstudios 1,120
That is how it is designed to be operated.
To make things easier, definitely make the leading edge as straight as possible. Also, try to make sure there are no overhangs or other issues with the end. You can cut on a bias (Not square to the length of filament) or, @tinkergnome told me a cool thing you can do, which is heat the end a bit and pull until you get a nice center taper and just snip the very end off and it will feed into the mechanism much easier.
tinkergnome 929
A straight first piece of filament and a chamfered tip is usually sufficient for me, no need to lift the lever.
The stepper motor has to be moving of course - @Jesse Marcel it sounds like you are not using the material load / change "wizard" from the printers menu - for any special reason?
