Wedgebot to the rescue. Great advice. Still a good idea to cut the filament at an angle . . .
- 2 weeks later...
Thanks for the thoughts. I've done some experiments based on the above (Wedgebot not necessary) ... I did find that cutting to a point didn't always help, but adding a slight bend at the end away from the catch-point made the difference.
- 2 weeks later...
14 minutes ago, steveprinters29 said:As per you mentioned, there could be a probable trouble with the feeder wheel of your 3D Printer and you need to get acquainted with this.
Use your 3D Printer’s user manual and find out the issues which affect the feeder wheel. And if you are planning to get a new 3D printer, you can get a good one at ‘3D Printers Bay’ at amazing discounts.
Thanks -- but I've done everything in (and outside) the manual. Having taken the feeder apart and also examined it in action, I think that there's a design issue which could easily be solved. I'm looking to see if I can produce a simple fix. And it seems a bit odd to be talking about replacing a printer that I've only had a few weeks.
gr5 2,099
First of all cut it to a point. Not straight. If you do only one cut then cut at an angle and make the longest part of the filament on the outside of the curve of the filament. But I usually do 2 cuts.
Secondly I recommend you load the filament manually using the wedgebot:
https://www.youmagine.com/designs/wedgebot-for-ultimaker2
I haven't used the menu system to load/unload filament in over a year.
