So if, I double the thickness of my wall from 0.6 to 1.2mm cura should be able to deal with it? I will give a try. I have calibrated my e step on my printer and my filament diameter and now when I print some parts and my flow is at 100% , my nozzle will grind the top surface when printing. So I was pointed out that it was overextrusion. From that point I realise that even if the extruder is well calibrated and the filament diameter was set properly, I still need to calibrate for the density of the filament by setting the flow to a lower value .
So if I print a thin wall of a set value like 1.2mm with a 0.6 nozzle and adjust the flow untill I really print 1.20mm, is it a good way for calibrating my flow%?
I have saw some trying to adjust by printing a small cube, but I don t belive that way is good because of the plastic retraction .
burtoogle 515
Hello @daoust, sorry but you have hit a big problem with Cura that it doesn't make a good job of thin walls. The problem boils down to the fact that all walls have to be printed as a pair of lines and not just a single line. Cura tries to make amends by providing "wall overlap compensation" which makes a second wall that runs close to a first wall thinner so as to reduce the overall width but, unfortunately, the overlap compensation has many bugs and is not guaranteed to make a good job. It remains a problem area.
