If the Z axis was messed up then the part wouldn't be the proper height when you printed it. It would look all squished flat. That's not the problem.
The problem is you are underextruding. How fast are you printing that infill? Cut the speed in half. You may have a defective printer. Have you ever replaced the teflon part? That is a consumable that needs replacing often.
I know exactly what you mean about the nozzle hitting the layer below. I've experienced that mostly on the edges of overhangs but also if I print infill too fast (just like in your photo). You can slow it down from the TUNE menu while printing but expecit it to take at least 3 layers to recover and stop scraping the layer below so much.
Hey, thanks for the reply.
Yeah you're right, a wrong Z-step would fuck everything up and I already thought that the infill looked under extruded but threw that out the window as I had no idea what could cause it. I already tried 10% speed (relative to the standart value) and it still moved through layers. The TFM Coupler? I've never replaced it, thanks for the heads-up. While I haven't printed that much I'll disassemble the printhead as soon as I find time for it and put a new one in.
gr5 2,230
SV-97 0
