Thank you so much for your quick reply. As you said I opened up the hot end and checked out the TFM coupler but could not change it because of not having a spare one but I have attached the image of it here which something looks like this from the top view.
I also cleaned up the feeder and the bowden tube and after reassembling the hot end I carried out the atomic method to clean the nozzle and the image of the PLA filament used during the atomic method looks like this.
Before all of this when I physically pulled out the filament from the nozzle because of not inverting of the material as I mentioned you before I got this.
Do I still need to wait for the TFM coupler before starting the print or the problem is something else?
gr5 1,870
Have you changed the PTFE/teflon part? That's the most likely problem. If that doesn't fix your issue I have a list of other things you can check but most likely it's the teflon part. They are considered an expendable. You should be changing it every 200-500 hours roughly. You can check how many hours you've printed so far in the menu system.
You can get a few extra hours while waiting for the replacement part by drilling it out with a drill bit of size 3mm to 3.25mm. Without taking anything apart (just remove the nozzle and drill upwards carefully). You can also remove the nozzle and insert filament from below to feel the friction in that part.
Also if you have never done a cold pull on a UM2 then read about how to do this properly or watch some videos of people explaining it.
