I using latest cura version. I try cura 3.1 with same results. All shells and printcores X/Y calibrate looks perfect. Problem is only on the top layer. Bottom layer looks perfect.
I use only 0.4mm printcore and line thickness are set to defaults ?. Part is only 1.5 mm high and I use 100% infill. I try set infill to 20 or 0 with same result.
Neosanding looks like ironing in cura. I dont need ironing because my prints are little bit curvy with minimal thicknesses (0.8mm) and ironing have problem with this shapes.
gr5 2,334
I have seen something that looks just like that when I accidentally sliced for 0.6mm nozzle (and line width was 0.5mm) and used a 0.8mm core to print it. It took me 3 prints before I finally realized what I was doing wrong (I had sliced it and printed a few a week earlier and forgot that I had sliced it for a 0.6mm core). So maybe check your line width and make sure it is close to the nozzle size?
Are you using cura? Maybe you need to go back to an older version. Are you using the neosanding feature? I can't remember what it is called.
