I've sure done this over and over and over
Use a good notepad program. Basically, keep everything until the first move away from the priming area and remove everything. The important bits are dealing with Z - you may have trouble homing Z with the print on the bed, but you can manually adjust the Z-level, and change the initial "home all axis" to "home X Y" only, and it'll pick up from your Z.
;FLAVOR:Marlin ;TIME:2456 ;Filament used: 3.37922m ;Layer height: 0.2 ;Generated with Cura_SteamEngine 3.0.3 M190 S68 M104 S205 M109 S205 M82 ; absolute extrusion mode G28;Home ALL G92 E2948.38352 ; Set Extruder position to "E2948.38352" OFFSET TO WHERE WE'RE AT on layer ten G1 E2947.9 F2700 G0 Z2.1 ;MASSIVE DELET BY ABE ;TIME_ELAPSED:2141.324905 ;LAYER:10 - START HERE G0 X44.942 Y-.311 Z2.2 ;TYPE:FILL G1 F4889.9 X46.471 Y1.216 E2948.38352 G1 X46.541 Y1.286 G0 F9000 X46.532 Y1.286 G0 X44.942 Y0.311
Here is some old code I'd edited to finish a failed print some time ago. Note my "massive delet"(sic), the comments explain most of it.
Hope it helps, Sir.
- 1
kmanstudios 1,120
I got back from my appointment and wanted to share what I found:
First a tutorial: https://www.3dhubs.com/talk/thread/how-rescue-print-stopped-mid-way
Second, the program is Repetier Host. You will find that link in the tut. I am still working out the kinks, but it seems ok at first glance.
