On 6/29/2018 at 3:42 PM, fergazz said:
Which infill did you use for that?
As far as I know triangular is the strongest. I also saw a video with a lot of strech testing and the best results where using 50% infill (stronger than 100%) and a lots of perimeters, around 5 or 6. Don't know if the forces applyed will match with this case but I will try to find this test in youtube
Edit: I found it... CNC Kitchen video. Also, keep in mind to print hotter (You should know about it but it can help someone else)... it will looks worse but will increse strenght. Also avoid PLA cause it's rigid but don't bend to much. Maybe nylon should be the best option for this apllication?
Of course that this is a software solution, not a design solution ?
JCD 28
Have you try to make a hole in your model up to the flat part and insert a big screw inside ?
