Printing now... I am really looking forward to being able to use adaptive layers without worrying about either wasting material or compromising on thickness. I had to always bump up the top/bottom layer count to make up for the thinnest top layer and wasting plastic on the top/bottom layers that are at the max thickness. This change you made will make adaptive layers worth using to me.
- 4 weeks later...
Awesome! Thanks!
I'd mentioned this on here before and it didn't seem to get any interest from the devs. Perhaps seeing it in action will sell them on it!! I'm convinced, anyway.
- 3 months later...
Incorrect info. Info about who created the test fix is already posted correctly above.
Edited by Adam324- 4 years later...
So, it's 2024 and several version of Cura later. It would be really nice if this were fixed at some point. I would really like to use adaptive layers, but it completely ruins so many top surfaces.
QuoteSo, it's 2024 and several version of Cura later. It would be really nice if this were fixed at some point. I would really like to use adaptive layers, but it completely ruins so many top surfaces.
There's a lot of things in Cura which would be really nice if they fixed. Unfortunately they only have so many people and so much time so they have to pick and choose, and they tend to choose things which aren't fairly niche cases like this.
If you want to get a bit creative, you can just slice something with adaptive layers on and then off, and transplant the g-code for the top few layers from the latter to the former.
Edited by Slashee_the_Cow
Adam324 13
Thanks! This is looking good to me. I brought back some of my old prints that I did where the top layers were too thin because of adaptive layers (causing bubbling and holes between infill lines), and the top layers are showing the correct thickness now.
https://www.thingiverse.com/thing:2764962
The Riser.stl from that was a problem to print using the previous adaptive layers implementation with a layer height of 0.2mm and adaptive layers set to maximum variation of 0.1 and a variation step size of 0.02. The preview looks good so I will go ahead and print it.
Edited by Adam324Link to post
