If you want full control over all material properties, including temperatures, go to Machine Settings and change the gcode flavor to Marlin.
hi and thanks for the answers. @gr5 Anyway if I set pla on ultimaker 2+ if i set nozzle of 0.8 on cura, the printer set 240°, instead if i set a nozzle of 0.4 for example the temp could be 210°?
I've found custom setting and it's seems to me the only way to set a temp. But have to try with different nozzle. I've tried flavor gcode of Marlin but i've got some problems with prints quality, shell doesn't are good, so i did a step back to ultimaker gcode to understand. But this day seem noting works. Does firmware of 3.3.1 can afflict the printer? Thanks
Edited by fablabdueville
gr5 1,506
There are other ways to do this but buy default:
Cura does not set the tempature. The printer does. You tell the printer what kind of filament you loaded (e.g. CPE, PLA, ABS, Nylon) and you can create different material settings in the "custom" menu if you want to create ones that aren't already built into the printer. Or if you want to change the values. You can set quite a few things including: fan speed multiplier, nozzle temp, bed temp, retraction distance and speed.
There's even a temperature per nozzle so if you tell cura you have a 0.8mm nozzle the printer will see this when you go to print that particular gcode file and it will grab the temperature for the current material and the current nozzle.
There's a way to set this stuff in cura instead. Or after the print starts you can change temperature in the TUNE Menu.
