Hey there, I know this is old but I had the same issue and this was the only thread I found on this issue in particular.
I have the flow calibrated so I didn't want to just increase it in the slicer to mask the issue.
After giving up on finding a solution online I started studying the layer printing path and I had a Eureka moment, it was an excessive retracting distance producing under extrusion, since the test I used to calibrate doesn't really show slight under extrusion problems I started looking for one that does
Did a test print using this site http://www.retractioncalibration.com/ and found I am getting slight under extrusion when using over 5mm retraction distance (I was using standard 6.5mm). After changing it in Cura to anywhere from 4.5mm to 5mm (Bowden setup) everything was printing perfect!
This makes sense since you got a bit of a better result after playing with combing settings. Worth a try.
Note that after changing filament or the tension of the extruder's clamping spring, you might have to redo the retraction calibration, since the effective diameter of the extruder gear would change (Teeth dig more in some material).
Also don't forget to do an E-Step calibration for the extruder motor.
Top Posters In This Topic
22
17
12
12
Popular Days
Jun 6
30
Jun 4
17
May 27
9
Aug 19
8
Deve 22 posts
kmanstudios 17 posts
mnis 12 posts
burtoogle 12 posts
Popular Days
Jun 6 2018
Jun 4 2018
May 27 2018
Aug 19 2020
Popular Posts
ahoeben
This is going to be the least constructive reply ever, but each time I see this topic I think "I don't need to know about your leaky bottom".
mnis
And yes you can try another surface pattern, but it should still be seamlessly closed with any surface pattern. For example, I like concentric surfaces, but these are not properly closed in Cura v3.3.
kmanstudios
This is literally my method of troubleshooting: 1. Do as @mnis said: Make a test object and test it on all three machines to make sure results are consistent. This is most imperative as it may po
Posted Images
wwolf 0
Edited by wwolfLink to post
