Cannot add new material profiles
1337Slewis
Posted · Cannot add new material profiles
Hi guys,
I am trying to add a new material profile for PETG, but after filling out 2-3 fields the software cancels the adding of a new profile and selects the ABS profile at the top of the list.
I have tried duplicating and creating, both same result. I have added material profiles before without a problem, but now it is not playing ball.
I have the latest update, restarted PC, everything I can think of.
Any assistance would be greatly appreciated, thank you.
    • 3 weeks later...
    On ‎5‎/‎28‎/‎2018 at 7:10 AM, 1337Slewis said:
    Hi guys,
    You don't state which machine your using, but had similar problems with my UM2 whilst trying to add PVA - looks like Ultimaker do not allow any 'materials' they think your machine can not run ?
    Have a look at this thread - I found a way around this problem ?
    https://community.ultimaker.com/topic/22932-cura-331-unable-to-add-custom-materials/?tab=comments#comment-209581
    UM3, but its rather irrelevant seeing as the issue is Cura.
    Thanks for link mate, you're a legend. This should get me there
