XY calibration sheet graphic is confusing
Posted · XY calibration sheet graphic is confusing
The text on the XY calibration sheet (both the old V1.5 version packed with my UM3 and the new V1.9 version that's for the S5 as well) does a pretty good job of explaining the operation clearly.
But I would say that the graphic showing you how to select a line actually confuses things again. The problem is that the difference in spacing between the Material 1 and Material 2 lines is much greater on the graphic than it is on an actual calibration print. So before I tried calibrating the real printer, when I looked at the graphic that was trying to show me 'See, choose +15 because that's perfectly lined up; don't pick -3 because that's off', my response was "Okay, but why wouldn't I choose -6? That's perfectly lined up too. Am I missing something? Would they both work?"
That situation -- two pairs of lines that are both perfect matches -- can't happen on the real calibration print (unless something is terribly off).
Is there a reason why the graphic takes this approach? Wouldn't it be better to use line spacing that better matches a real calibration print?
    • 6 months later...
    They would not both work.  You should choose -6 in the above case.  It is indeed a bad example.  You want to choose the closest value to zero which may be positive or it may be negative.  Typically it will always be less than 10.
