ok thanks @fbrc8-erin I did not do a factory reset i'll try that. Edit: it worked!
Edited by Jeremifbrc8-erin 296
Glad it worked! Definitely always do a factory reset after a firmware update; it's the best way to make sure all the changes really go through.
fbrc8-erin 296
Did you do a factory reset after updating your firmware? Sometimes new profiles don't show up after a firmware update unless you factory reset the printer.
PP should be fine for a UM2X+. It uses the same feeder as the UM3.
