fbrc8-erin 287
Definitely check your printhead shafts like gr5 said, and checking the lifting switch function by hand. Also, if you perform the lifting switch test in the Diagnostics menu, does it work? If not, try doing the liftings switch calibration again following this video:
1
gr5 2,194
Try changing the nozzle height with power off by pushing the head into the switching mechanism and sliding it forward and backwards. Does it work? Or does something hit something such that it won't go in properly? Also check that your thin rods that go through the print head appear to be perpendicular when looking down on them from overhead.
