I am using the Micro Swiss Wear Resistant Nozzle, which is a brass nozzle with nickel composite coating.
I did re-level the bed.
I did not tighten the nozzle while it was hot.
Bed adhesion doesn't seem to be the problem.
And I am not getting any leakage between the nozzle and the Olsson block.
cryptie 0
What kind of nozzles are you using?
I had to up the tempurature a bit on my 3dsolenx block to acheive the same quality as I was getting on my stock block.
Also, have you tightened the nozzle to spec while warm, then done a bed leveling?
