kmanstudios 1,073
On 7/23/2018 at 6:34 AM, Pepa said:When we stick the sheet to the glass, bubbles appears between them
An old trick is to take a needle and poke the bubble and smush the air out of the bubble to increase contacted surface area. And, then you got @jakepoz's suggestion to consider.
I have absolutely no experience with the material you mentioned though.....
jakepoz 2
I've used the GeckoTek products which seemed better reviewed than BuildTak. The only trouble is that sometimes parts stick even too well, and could get damaged when prying them off. But seriously, have been able to finally make large (taking up the entire plate) designs with zero warp.
https://www.geckotek.co/
The product that just sticks on like an adhesive sheet worked best, it might even be compatible with auto leveling. (Using an UM 2+ here)
